ok guys heres the deal..after buying my car i notice the batterie was always low so i replaced the alternator,after still having the same issue i replaced the batterie and still the same problem . if i dont start the car in a couple of weeks the batterie will die. i did a search on the subject an found that alot of people recommend removing the fan relay. witch i have done today i also checked my hood and drunk bulb and they do turn off when you close them both..does anybody have any more ideas, i dont think it was the relay switch cause it looked new i even opened it and it was all nice and clean with no moisture
