turbojimmy
Supporting Member
- May 26, 2001
I have a new snowblower with an 8HP Tecumseh Snow King engine on it. I've used it twice. This year I fired it up and it wasn't running right. I figured it was old gas. I put new gas in it and it does the same thing. It won't idle and does this cyclical thing with the RPM - up and down, up and down, up and down. If I put on full blast and push it into the snow (a load) it works fine but you can tell it's not running right. I took the carb off of it, took off the valve and made sure there was nothing stuck in the needle valve. It seems to be a fuel delivery thing but I don't know where to start. It seems if I hit the PRIME button while its running it makes it run better so I figure it's lean. Plug is fouling though (carbon).
Any ideas?
Thanks,
Jim
Any ideas?
Thanks,
Jim
