Hey guys i noticed today that my car is smokeing at idle but very little.When i first start it it puffs alot then smokes very little at idle.My heads are new from champion.My turbo is new and checked play seems ok and no signs of oil where the turbines are.I want to check everything before i come to a conclusion that it is the bottom end.Guys please i need more ideas as to what to check. Oh ya the smoke is blue in colour and it does smell like oil if you put your hand over the tail pipe.Is there anyway i can check to see if the heads are the problem, will i be able to see anything obvious if i pull of the valve covers?I dont notice any performance problems.Thanks for any help.
If it is the pcv sucking oil will the pcv hose that goes between the pcv and plenum be full of oil?
