Smoking problem still
Beecha91
Hey guys,
I still have this problem with smoking oil out the tailpipe every once in a while. It only seems to do it after the car is hot, and after boosting a few times, or come to a stop after getting on it. Itll only smoke for a few second and then usually stop. If i drive the car like a grandma it wont smoke at all. I took off the dp the other night and saw no oil on the exhaust side of the turbo, so i dont know whats going on. I did see a chip in one of the fins tho, didnt see any real shaft play either. So should i stay with my plans of sending the turbo out, see if it helps any. Or just bolt everything back up and look for another source? Any help would be great, Thanx a lot
it sounds like a turbo problem, although it could be an egr problem i suppose. Might unplug the vac hose(plug it) to the egr valve itself, and see if there's a difference.
