The only oil I see is at the weep hole on the bottom of the dust cover. I cant see or feel any oil at the valve covers or backof the intake or any where else. I'm going to check the pcv valve and make sure it is checking. Forgot to mention that I have replaced the rope seal with a neoprene victor seal. Haven't had any problems with any leaks since then, only a minor seep at rear seal. It just started this smoking under boost the last couple of times I've driven it. I only drive it 2 or 3 times a month.
TE44
Blue Tops
TH Downpipe
Walbro pump
Hot wired
Adj Regulator
Adj Wastegate
Thrasher Chip
