Alright, here's the story. I bought a car that was sitting for a while. It had the original powermaster switch that didn't get the recall. Brakes worked, but the pedal was real hard. I put in the new switch, and popped off the cover. The pass. side resevoir was almost dry, so I filled it up. After some pumps, the brake pedal got softer. The resevoir got empty again, so I filled it back up. Put about 15 ounecs of brake fluid in. There is nothing leaking that I can tell, and the resevoir is staying full. Now the brakes work, and the pedal feels ok, but still soft. It will go down to the floor, but it will apply the brakes before then. Is it possible that I just have air in the system now? If so, should I start bleeding at each wheel?
Sorry for the long post, just wanted to be as accurate as I could. Thanks.
