Solid cam w/modded ECM
BUICKTR
Just wondering if anyone has run a solid cam using stock maf and a modded ECM. Just wondering if Knock retard could be disable on a chip. I know it will set off the knock sensor, but is there a way around it.:confused: Thanks!! Gilbert
just unplug the knock sensor and all will be fine. The ECM wants to see the knock module connected.
A chip can be modded to eliminate all that, if you want to remove all the hardware..
Bob
TurboBob
Thanks! So having the knock sensor unplug won't trigger any malfunction codes to my ECM? I'm glad to hear we could eliminate the knock module on the chip. :)
