installed an 87gnx engine and underhood engine harness in 88 monte carlo ss and have no pulse at injectors.i have power and no ground.if i follow the gm manual it says to check for juice at terminal b at the crank and cam sensors using terminal c as ground.these tests show i have a refernce signal and ground at the sensors.if i jump them as per gm they dont fire (ground ) injectors.remeber i do have 12 volts at injector harness with key on ,a check engine light that functions and spark.i have a new ecm,chip,coil pack and module as well.also i have no fuel pump relay voltage from fusible link or with key on as the harness mating to the firewall probably doesnt have these connections.i know this as i have done the conversions before but used the dsh harness from the gn and didnt use it this time as it was not removable from the wrecked car..need to know how the relay is juiced up,not like key on power and fusible linked juice all the time.want to know where the wires go and if they in any way can stop the ecm from grounding the injectors.according to the factory manual the drivers are bad but this is not true.please offer assistance with schematics please.
