Spring Special: Scanmaster G for XFI/Classic
TurboBob
Resident mad scientist
Staff member
We are kicking off a spring special on the Scanmaster G for XFI/Classic. The sale is running until the end of Feb. Regular price 269.99 , on sale for 219.00 shipped. You can order at www.scanmaster.bailey-eng.com
some videos:
(thanks to Patrick and Brian for these!!)
Bob
Hi Bob, ordered one yesterday. Does this come with a long wire lead to reach XFI ECM under the passenger seat?
Can someone please post up idiot proof instructions on using the bluetooth function on this when using it with Classic fast.
I am using a laptop with built in bluetooth but can't seem to connect through CCom.
The laptop is showing that it is paired with the Scanmaster but nothing else is going on.
what port is it assigned to, you need to select that port in ccom.
thats all thats required to make it work. should connect once the gauge is talking to the ECU.
drop me an email and we can get deeper into it.
Bob
Bob, what parameters does the Scammaster G display for the FAST Classic?
Juan
wideband afr
knock retard
MAP
Boost
Target AFR
Volts
O2 correction
Coolant temp
Air temp
RPM
TPS volts
TPS Percent
VE
Injector Pulsewidth
IAC
Trouble codes
Spark advance
Fuel energy constant
