Squeaky belt!! whats the deal??
RUQWKNF27
Here lately since the coled weather has moved in my serpentine belt is squeaking like crazy. I do notice it is louder when I come to a stop. Obviously cause there is less pull from the motor. What can be done about this ??? belt has 3600 mi on it.
try armor all it has kerosene in it and it grabs keeps it soft
See if you have a 640K6 or 635K6 belt. A lot of manufacturers substitue the larger belt because they do not make the shorter 635 belt (63.5 inch). With a 640K6, most engines will have belt squeal.
After having several belts only last a few weeks before stretching out to the tensioner limit, I'm pretty sure I went with a 630. As mentioned, the belt called for in the parts store computer is wrong, and they "rounded up" to the next size they carry. I'll check when I get home to verify the belt size I use - I keep the package hanging in the garage for reference.
Some of us have had great luck with the Goodyear Gatorback belt..
Part# is 4060635....The 35 at the end denotes the correct length for our cars
