John Purdom
BLACK SABBATH
- Aug 12, 2002
For those using or considering stacked steel headgaskets such as RJC sells, a bit of advice to avoid a major problem.
After my total rebuild, my car would oil smoke badly, especially after accelleration, then idle, as well as drip from the breathers.. Went thru all of the usual suspects including the turbo (was new, Limit), PCV sys, guides, leakdown (perfect) etc. Finally after pulling the heads, this is what we found.
Most of the oil drainback holes and water passages in the headgaskets were blocked with the silicone sealant. The oil was puddling on top of the heads.
Understand that this was our fault, not Jason's. The rebuild was done in the winter, and the silicone was obviously too cold to spread thin enough with the supplied roller. This application needs to be paper thin, almost as tho you sprayed it on. If you see squeezout when you torque the heads, you are probably going to have a problem.
I hope that relaying our mistake can help someone else. I feel lucky not to have damaged the lower end from oil starvation. My saving grace was that I wouldn't drive the car in "mosquito fogger" mode, so it saw little use.
