With that casting number and 2 bolt caps, this would most likely be a 4.1 Stage 1 block. Check the lifter bores. If the oil galley goes through (intersects) the lifter bore, it has production oiling and is a Stage 1.
Stage 2 used the same casting but modified the machining. The oil galley runs along side the lifter bores but does not break into the bores. Stage 2 had the oil pump pickup at #1 main bulkhead, while Stage 1 has the pickup in the stock location.
I've seen alot of odd variations in stage blocks........Post some pictures
