Well, I'm finally at the assembly part of my motor build. WOOOHHOOOOO!! BUT, I put the drivers side TA header on the head today and went to stick the oil dipstick tube in and now I'm hitting something. It will only go in about 1/2" or so. I originally thought maybe it was hitting the oil pick up tube but then realized the pickup is on the passenger side of the block. I'm thinking it may be hitting one of the main caps. Have you guys run into this problem? It's a 3.625 crank. I also am wondering if it may be hitting the oil pan? I'm using an RJC pan. I'm posting a pic of the bottom end. Any ideas? Thanks much! ------Jeremy
