Cheeseburger
- Jan 25, 2004
Ported polished BMS intake manifold with injector bungs welded in place along with fuel rails etc.
Has a plate welded to the back of it that fits a coil pack/ign module perfectly.
Upper plenum is included which is a ported/polished 70mm Hemco that i modified for perfect port match to the intake.
This will work perfectly with a 70mm t-body and your stock throttle cable and so on, no custom modifying of throttle brackets/tps and so on!
Asking $850.00
Contact prov62003@yahoo.com
Thank you.
Asking $850.00
Thank you.
