I run an Art Carr 16930 NLU that stalled about 3300 with a stock block. It stalls around 34-3500 with the 274 S2 heads and a BB T-76 Q-trim, and it's plenty of converter. Granted, I run a small cam (222/218 HR), but it shreds tires at will.
When I was running a modified 60-1, it was stoooopid!
I plan on going to a 4L80e after awhile so i ll keep the boost low until then, i also have a built 350 trans i could throw in there. it will also have a strange 12 bolt rear.
Does the strange 12 bolt have the upper control arm mounting raised? The Moser housing is and it helps a bunch to plant the tires at launch. One inch is the distance.
That stall should work just fine. I hope that's not at zero boost. That could be wild.
I havent received the 12 bolt yet-its brand new, thanks for the tip-i will definently check on that. i have metcos uppers and lowers and also a upper panhard bar if i need to weld it in plus the H&R rear swaybar.
