D16Y8Turbo
- May 3, 2002
Can anyone help me? My bro has a '87 Buick Grand National that stalls from 4700 RPM to 5000 RPM's. Timing doesn't feel like its being pulled. We recently put 43 lb injectors and a fuel pump from Red Armstrong on the car. He also burnt a chip for us with the new upgrades. The chip he burnt for us, is when it only happens for. All the other chips the car doesn't stall but doesn't run as well either. The car also doesn't want to shift with this chip after it stalls at 4700-5000 rpm's. Any suggestions on what's causing this?
On another note, I also had s-10 wheel cylinders installed in hopes of holding more boost at launches. But the car only holds 2 lbs of boost vs. 7 before. Any suggestions here how to get more boost at the line?
Thanks in advance,
Jonathan Hinderer
Thanks in advance,
Jonathan Hinderer
