Alright...I had and still have but not as bad...a water leak from the passenger side of my block. It looked as if the leak was coming from the drain plug...so I installed a new brass drain cock and thought that would cure it.....well went out yesterday morning and it's a little cold out and look under the car and I see antifreeze on the ground. It's not as much as before but still leaking
By the way I have not filled the block back up with antifreeze yet so how could it be leaking from the drain cock? Also has anyone ever installed freeze plugs with the engine still in the car? Anyone know a sure fire way to find the leak? Thanks
