I took offa turbo and put a new one on and now I have a little exhaust leak from the passenger's side header.It never leaked without a gasket before.I was wondering if I should use the Fel-pro 1400 gasket.Do they hold up well???Another thing is when tightening the header bolts to the head the middle and first top bolts seem to strip every time.Maybe this is due to not sequencing the bolts in order.I have iron heads and I know there not stripped just wonder why the bolt about 3 quarters down strip all the time.I went with a longer bolt and it did not strip.Maybe I need to use longer bolts on the 3 on the top???Are you supposed to tighten these bolts a little at a time???
