stock pcv system
stockv6
How many of you still have the stock turbo pcv system? My GN is mostly stock, never been apart and I get enough oil sucked through it to pool on my power plate.
I did not notice this condition before my mods over the winter, chip, adj fpr, walbro 340, k&n, full guages and a scan master.
Will the iac setting effect engine vacuum and have an effect on this? It was at about 50, now it's 15 in park, engine warm.
tia:)
I just changed the pcv and did "spring cleaning" aswell. I installed a gm replacement which tests fine.
As said, check the previous threads on this. Check valve will NOT help, as it keeps boost from going INTO the crankcase.
For some reason this happens to a lot of people with power plates, probably because they have had their intakes apart to notice it.
Do you have valve cover breathers?
