Gonna build a motor slowly over the spring.Gonna use the new eagle crank and forged pistons in a standard 109 block.Just wondering if I have to go to the high dollar rods?
Plenty of guys on here with full weight (3500-3700lb) TRs running mid to low 10's with the stock rods and some of them have even run in the 9's.... This tells me the stock rods can handle about 700-750hp at the flywheel..... Just make sure you use the ARP rod bolts and you should be fine
