stock tape deck radio with aux input
Discussion in 'Car Audio' started by ryan319, Jul 16, 2010.
  1. ryan319
    ryan319
    Expand Collapse
    Aug 21, 2006
    343
    3
    Offline
  2. TurboSpeed
    TurboSpeed
    Expand Collapse
    Oct 13, 2008
    118
    0
    Offline
    That would be nice, because im keeping my GN stock radio and a ipod hooked up to it would be sweet. So i would like to know as well.
  3. RegalT-type85
    RegalT-type85
    Expand Collapse
    Jan 23, 2010
    934
    0
    Offline
  4. ryan319
    ryan319
    Expand Collapse
    Aug 21, 2006
    343
    3
    Offline
    i have an FM transmitter and it sucks. i even spent money on a good one from best buy. it was like $70 and it's still a POS. basically they all suck from what i've heard.
  5. garyk1970
    garyk1970
    Expand Collapse
    Electronics Moderator
    Staff Member
    Nov 4, 2005
    3,498
    129
    Offline
    click on the aux input link in my sig....
  6. ryan319
    ryan319
    Expand Collapse
    Aug 21, 2006
    343
    3
    Offline
    the wiring seems straight forward. so i no need to jam something in the tape deck to fool the radio into thinking there's a tape in there? what did you use just so i have an idea.
    i've seen other solutions that run off of a switch. switch one way to listen to the radio and switch another to listen to ipod. or i think a switched 3.5mm input plug would also do the same thing. any idea how to do this.
  7. "Turbo-T"
    "Turbo-T"
    Expand Collapse
    V6 on steroids
    Jan 10, 2007
    5,809
    14
    Offline
    Ditto on the FM transmitters...they allow too much static and such to be caught up on whatever freq. the transmitter is working at....so you're driving along and all is fine then you run into an area where another station (that is weak but audible) is trying to use that same freq. and now you're faced with static and such.
    Looks like for the most part the way it works is you're tapping into the tape head wires....isn't there a way you can set it up so you're not having to push in on the tape heads with popsicle sticks when you want to listen to an iPod? Like maybe an "aux" switch on the radio that lets you just flip to the jack inputs w/o messing with the tape player's components?
  8. 38turbo
    38turbo
    Expand Collapse
    Oct 5, 2008
    226
    4
    Offline
    i bought one of the ones off ebay and i dont have to push in the cassete to trick it when i plug in the cord it just takes over
    the only thing i wish was different about it was that it would make the power antenna go down when the mp3 player is plugged in
  9. garyk1970
    garyk1970
    Expand Collapse
    Staff Member
    Nov 4, 2005
    3,498
    129
    Offline
    if i remember right,you ground one of the wires (left in the five pin plug....
    red, red/white, or brown)
    to switch to the cassette....this way you dont have to "fool" the tape player by inserting something...
    use a toggle switch,or wire up a contact when you plug up a ipod jack,it will ground out the wire,thus switching over to aux.....
  10. garyk1970
    garyk1970
    Expand Collapse
    Staff Member
    Nov 4, 2005
    3,498
    129
    Offline
    put the power ant trigger lead behind radio (pink) on a hidden toggle switch....
  11. "Turbo-T"
    "Turbo-T"
    Expand Collapse
    V6 on steroids
    Jan 10, 2007
    5,809
    14
    Offline
    That's what I'm after....something that over rides the tape or radio audio when a 1/8 male pin plug is inserted into the jack. If anyone had a schematic on how to do this, that would be great.
  12. monteperformanc
    monteperformanc
    Expand Collapse
    Jan 15, 2009
    331
    11
    Offline
    I tried to figure this out a few months ago. These guys that sell them on ebay are REAL secretive about how to wire it up. I'm pretty sure they interrupt the FM radio signal. One guy said if I shipped him my radio he would install the aux input for around $40 plus shipping each way. I have not done it yet.
  13. Sweetwater GN
    Sweetwater GN
    Expand Collapse
    Unstoppable :)
    Jun 1, 2010
    70
    0
    Offline
    google 'fm modulator', I used one made by audiovox and it worked good. Goes in between your antenna lead and the input to the stereo.
  14. Cadillac7834
    Cadillac7834
    Expand Collapse
    Oct 1, 2016
    12
    2
    Offline
    IMG_1059.JPG I'm going through this same problem 7 years later, lol. I have a 84 but my Delco cassette player only seems to have a 4 pin connector. Any idea which wires are - + and which are the audio inputs to splice a aux port into?
  15. garyk1970
    garyk1970
    Expand Collapse
    Staff Member
    Nov 4, 2005
    3,498
    129
    Offline
    Can you follow them to the tape head?
  16. Cadillac7834
    Cadillac7834
    Expand Collapse
    Oct 1, 2016
    12
    2
    Offline
    Yeah, I should of taken a picture of the tape deck end. I'll double check when I get home, they all go to the circuit board. Below 3 of them there's a + and a L I believe but there offset donuts hard to tell which wire it corresponds too.
Share This Page
