I have stock turbo/injector/IC, alcohol, and boost commander. I have noticed that my max boost is 20-21 lbs in 2nd gear, but higher in 3rd. Here's the details:
BSTC is set to max and 3rd gear scale is ~20% ( I'm shooting for 22 lbs in 1st and 2nd, 21 lbs in 3rd), but I'm only getting 20-21 lbs in 2nd, same in 3rd.
I tighten the WG rod in an attempt to get one more lb. 2nd does not change (remains at ~20-21), but 3rd does go up 1 lb to 22.
It is consistant.
This is odd. Waddya think? I had not noticed this prior to my valve sping and timing gear change, but I don't expect it to be related. The boost will spike to ~24, but settle close to 20, then rise after the 3rd shift.
It is consistant.
