Stripped oil pressure switch head, what now??
87gninpa
Was removing my stock sending uinit to install a OP guage, the head stripped. I used the correct tool and it was sooo tight that when it finally turned it just turned on the head of the bolt. ANy ideas on how to get this out????
how can i get it in there? and its soooo tight on there i dont see it coming off like that...
Stripped Sucks
Hey GNINPA,
Try to use an electric heat gun and heat the area a little. If there is enough bolt material left try to tighten it first to break the frozen seal. Then use a vise grip small enough for the area and it should loosen up. Good luck and hope this helps you.
