Drove the car all the way home with no issues. Been testin out the propane system. I pop the hood after I notice my first issue, it feels like its pulling timing under lower mph hard acceleration (with no knock and normal O2s). I can floor it in 3rd gear and run it up fast with no knock either. I was seeing some 860+ O2 readings so I figured it was a little rich. I checked the Translator box and it was set on "No change" for the "rich/lean at WOT" setting. I gave it a couple clicks to 4% lean and then double checked all the spark plug boots and made sure they were all on tight.
Now when I floor it, its running super rich all the time, even idle. and I cant get the boost up past 10-12psi. Was running about 18psi with the propane. I'm getting some smoke under acceleration too, from the color looks like from it being too rich. and the RPMs arent going up, gets to a point close to 4K and getting a strange exhaust noise that sounds like a rev limiter or something.
I'm stumped.
I'm stumped.
