Sway bar end links for LE1 bar
Pronto
Believe nothing you hear and half of what you see.
What length link do I need for the LE1 bar with a stock suspension (not lowered)? I was searching the suspension sites and they list a mess of sizes. I really don't want to mount the bar and then measure and then order something just to wait if I don't have to.
Thanks.
Mike
If you want cheap, I would install what is stock for your car. If you want fancy, check out http://www.guldstrand.com spherical end links for the F-body. They are adjustable to fit about any length and won't compress or flex like stock. The install is very much like stock. With car sitting on level ground just adjust till snug without preload to either side then tighten nut and go!:cool:
Fancy, you ain't kidding $189 for swaybar links :eek: :eek:
