- May 28, 2001
Am considering the removal of the 7/64" restrictor in the converter feed passage on my T-400. [Supposed to reduce thrust brg loading w/ t-brake use.]
I am doing this to confirm/ eliminate the possibility of reduced oil volume to the converter as a cause for high slippage and subsequent loss of performance.
[Have the same problem, "driving over the converter" on 4 different designs on 2 different brands of converters.]
Has anyone done this mod and found the above problem to be present once done??
TIA,
TIA,
