T.V. Cable Adjustment
dirt
Could someone look at the picture below and tell me if my T.V. Cable is adjusted correctly? The cable will not automatically adjust itself by the full throttle method. thanks
Car: 1987 G.N. stock transmission and torque converter.
If all is factory stock, 5 Indents are the factory position, but you have a problem. The bracket looks to be bent and is not supported at the bottom. You are missing the hardware to support the bottom of the bracket. Your coil pack is also missing a nut.
