SignUp Now!Originally posted by strikeeagle
49s have dipped into the 10s with the proper, complimentary parts!!!
But I'd get a 44...
Originally posted by Snorman
I consistently run 12.0@115mph with a 49 at 24-25psi on a 100% stock longblock (even stock valve springs), stock intercooler, 50's, a 3" Mease DP/testpipe and Hooker catback. I'm running a small 2800 TC, but a 49 will work well with a stock TC. Like Gn-ing, I was going 12.6-12.7's at 106mph with the stock turbo at ~20psi on 100-unleaded (with stock injectors).
I've been running the 49 since last July and loved it since the day I put it in the car. IMO, with the Mease pipe, it spools faster than the stock turbo/DP combo and has the advantage of making nice power at ~25psi, long after the stocker has given up.
S.
I now run VP110 (purple) since I can get it cheaper than I pay for Sunoco GT100 at the pump. I put very few miles on my car, so I don't mess with alky/propane etc.I've been running 100 octane unleaded..at 20lbs...no or very little knock..what fuel do you use with the TA49's at 25-27 lbs boost..and if i try the orginal turbo at say 22-23lbs..will it perform better? Do head gaskets hold up well at those boost pressures?...I have a stock 73K eng,with the mods in the sig..
