There are many differences between TA heads and Champion heads. There are 2 versions of TA heads, street and strip. The strip heads can use 2.02" intake valves and are CNC port-matched to Felpro intake and exhaust gaskets.
As far as flow numbers, unless you see the figures and know the source, most of these for ANY head is just what someone has "heard" or thinks.
I personally doubt, from our flow bench work, that an exsisting TA head could be made to flow 300 cfm? We have numbers on a few sets of TA and Champion heads and both sets can be made to flow impressive numbers. The only dyno numbers for TA heads I know of available were done by Ken D. and exceeded 1100 HP.
The TA heads are built for high boost application and are fortified in many areas to withstand abuse and not break. All finished casting are able to use 8 or 14 bolt patterns which is why a removable rocker "stand" is used. This steel backbone also adds strength and clamping force to the head.
There have been many sets shipped and even one customer had them for sale as he decided not to use them. Best way to obtain a set is to contact TA, or a distributor, and get on the priority list. Hopefully, in a few months, there will be sufficient shelf-stock and heads will be available for immediate shipment.
My set has been done and is to be installed on a TA alum block and running in about a month. Dyno runs are not planned but but lots of track time is!
