Tall ball joint question
Geezy
415
47
28
37
Suspension question for my 1987 Buick Grand National
I bought some UMI upper & lower control arms ,and they come with Standard Pro forged Ball joints.
I have brand new in the box pro forged tall ball joints.
My question do I just install the tall ball joints on the uppers and leave the standard ball joints on the lowers? Or fo I install tall ball joints on both upper and lower arms?
I have 2wd blazer OEM spindles & I will also be installing Aldan American coilovers with the arms.
Thanks in advance fellow Buick owners
1KWIKSIX
2,187
199
63
Mississauga, Ontario, Canada
maybe not completely, but it's reduced significantly.
UMI Tubular Upper & Lower control arms also aid by relocating the position of the ball joint and facilitates greater adjustments (caster / camber) by your front end alignment expert.
Geezy
415
47
28
37
Thank you for your input! Bumpsteer is the only issue setting me back from fully enjoying my GN after its 15 year hibernation.
Geezy
415
47
28
37
If the UMI upper arms will work with the tall ball joints, install both the tall uppers and lowers. It is the tall lower ball joints that eliminate the bumpsteer.
Thank you! That was the answer I was looking for.
I had planned to do it any way just wanted make sure, and ask again
Turbo6inKY
Short Guy
Jun 18, 2001
1,515
362
83
41
Louisville, KY
blog.andrewdscott.com
The answer you got is not accurate.
Bumpsteer is a function of the lower control arm, spindle, and the tie rod ends.
The upper ball joint does not affect bumpsteer. The lower ball joint directly affects bumpsteer.
Do not replace the lower ball joint with something of a different length without some kind of bumpsteer correction.
There is no bolt and go bumpsteer correction. It's something you must install, measure, adjust, and measure again. The UMI kit gets you close.
Geezy
415
47
28
37
I am installing UMI upper control & lower control arms with coilovers, umi sway bar and a bumpsteer kit being installed. I figured I install the .5 ball joints which will lower the car 1” and then lower 1” on the coilovers. And should retain the stance I currently have.
Turbo6inKY
Short Guy
Jun 18, 2001
1,515
362
83
41
Louisville, KY
What do you use to measure ?
The easy way is to set up a grid on a piece of wood (peg board with the holes connected in sharpie works) and put that in front of the car. Then you get the car up off the ground, remove the wheels, front springs and shocks. Attach a laser pointer to the wheel hub so it paints a dot on your grid. Draw a plumb line through the dot on your grid. That's your toe line.
Then you cycle the suspension up and down and measure where the dot goes. If it moves left or right of the toe line as the suspension moves, you have dynamic toe change, aka bumpsteer. Adjust the tie rod pick-up point until you minimize the lateral movement of the dot.
It sounds simple, but it's time consuming. Each time you adjust the pick-up at the steering arm, you have to set the suspension to ride height, reset the toe, then cycle and measure. Then repeat. It's nearly impossible to get truly zero bumpsteer, but you can get close.
Repeat on the on the other side.
  • Like
Reactions: JAMCAR223
Geezy
415
47
28
37
Any alignment shop can do this?
T-CHRGD
1,300
106
63
Bethlehem PA
That’s what I thought.
Turbo6inKY
Short Guy
Jun 18, 2001
1,515
362
83
41
Louisville, KY
Doing it with a bumpsteer gauge is very much preferable to the laser pointer method.
But depending on how many times you're going to do it (probably once?), it might not be worth the cost. If you could borrow one, that would be the bees' knees.
Geezy
415
47
28
37
Ended up installing upper and lower tall balljoints and only lowering the car 1” on the coilovers and aligning to UMI spec sent with the A arms and seems like my bumpsteer is pretty much gone! I found a shop that would do the bumpsteer measurement but figured I aline it and try it first since a rate of price could not be given. For the first time ever my Gn was able to go 55 mph+ with it haveing me fear for my life. Thank you to all who responded with the knowledge and know how. Now I just need to adjust the aldan american shocks to a bit stiffer setting.
One more question somewhere I read that the Gnx inner fender wheel wells had the the GN bulge removed???
Where can I get a set or can I cut that it off? On big dips my tire rubs
Thanks again!!!
Geezy
415
47
28
37
GNS Performance has the wheelhouse extensions that trim the inner fenderwell only, whereas the whole fender was cut out on the GNX.
https://www.gnsperformance.com/bodyframe-g-body
Here are some photos of the GNX fender mods I've found over the years wondering the same thing.
Thank you for all the info!
Any idea if I use the extensions, it will look stock? I just need that bump gone, not trying to put GNX fenders at all
Top Bottom
