TE60 turbo (.63 AR housing)
87geeinn
Buick and AMG pilot
Has some minor lateral side-to-side play but worked perfectly before I upgraded. Compressor wheel has NOT contacted the housing. The one downside is that I did some extensive port work to the wastegate hole. Worked fine with my 3" downpipe (G-Bodyparts style). If you have a larger wastegate puck, such as the RJC, you'll definitely be good to go. The below pic shows the measurement at the widest part of the opening (about 32.5mm / 1 9/32"). Could be used as a backup turbo or rebuilt and a new housing added on if needed. $175 OBO shipped to CONUS only. PayPal gifts accepted.
Thanks for the fast response geeinn I'm going to pass this time favian it's all yours
Sent from my SCH-I545 using Tapatalk
