SignUp Now!pacecarta said:can be done with engine installed and you dont even need to jack the car up
just twist it one revolution while you slide it down , should be plenty of room and you shouldnt have to fight it , have a bungy cord handy to tie the top near the turbo (or have a friend hold it from dropping ) then go underneath and hslip it into the cat or test pipe , then go back up by turbo and bolt it on (use antiseaize on the bolts, then go back under car and and install and tighten the band clamp to the test pipe or cat
that was the hard way. I know ATR made a TH knock look alike but I don't know about the installation. if it is a TH pipe like everyone keeps saying it just screws in with about 1 complete revolution.SPOOLFOOL2 said:I screwed mine in from the bottom. the car needed to be about two feet off the ground to work.
pm87tb said:No its to pieces the downpipe it self and a dump and i do have a band clamp...![]()
