Thrasher vs. lubrant 93
paccio
I was running the lubrant 93 street chip. I was running about 18-19 psi with that chip.
It seemed a little slow to spool so just got a 92 thrasher chip,
herd good things about them.
When i ran the car it know is around 20 psi, Without adjusting anything.
Why the higher boost level? is that built into the chip?
The car spools much quicker and seems to run better.
I'm running 100 octane on the street sometimes i'll mix it with 93.
o2's running 780-820. 0 knock.
The boost solenoid goes wide open in 1st and 2nd with the thrasher to give quick spool. sometimes, this can lead to an overboost on faster spooling combos. There is really nothing you can do to stop this so be sure you have enough octane to avoid knock.
The T93 is a good stoplight/daily driver chip, but don't use it at the track. Boost and timing go away in third and people will pass you like you are standing still. Use a T100 or T108 at the track with good gas and your car will fly.
