87GNcospg
Send your Donations
- Jun 23, 2003
im still a newbie to a few things under the hood of my buick, so if the following few sentences make some of your heads explode cause i dont make any sense than i am sorry.
alright, so when our cars begin to knock, the computer will lower/pull back the timing of our vehicles. correct? which is like a safety precaution to try and stop the detonation that is occuring. lowering timing makes you go slower right? i have heard that the stock chip has about 24*(?) and i have just put in a reds 93 which has 20*(i have been told). well if the reds is lowering my timing but i am keeping my boost at the stock setting (14-15lbs), will this make my car slower than if i were to keep the stock chip in which has more timing? i ask because i have heard that lowering timing but adding more boost will help you more, but if i am lowering my timing and not touching the boost than it seems like i am only hurting the speed of the car. reason i am not turning the boost up is because i have the BstC but only a single solenoid and no adjustable wastegate, so my range is 8-15lbs of boost. plus i havent purchased a scanmaster so i am just being safe for now. if i am totallly wron about timing,boost and blah blah please let me know and direct to a place that will explain it all to me.
