TURBOELKY
- Jun 27, 2005
were there any double roller chains ever made that you still used the factory tensioner? The one on my engine is a double roller, but still uses the tensioner, and lately, seems like its in need of being changed out. The engine starts to jump around really bad after it warms up, and is in park. under load its fine??? fuel pressure does not drop, idle fluctuates +/- 100 rpm, spark is good, timing is good, no vaccume leaks, every thing is perfect. Seems like maybe tension on the chain is causing this problem? maybe some slack gets in there, causes the timing to jump around a little? cant figure it out, but car runs great, just does this at idle in park only. In drive, its fine. any thoughts?
