timing
chris_mile
Senior Member
got my engine back from the machinist said its on #1 but the timing bracket doesnt line right up should i line it up my self? the balancer looks off by quite a bit. here is a picture.
editPhotos.fcgi
You can rotate it to TDC but you'll also want to know if it's on intake or exhaust if you're looking to put the cam sensor in.
no i know its at tdc but the notch looks off. did you see the pic? the cam sensor isnt the issue right now.
hey greg, will you go any lower on that aluminum bumper support? do you still have it?
you know what i was tightening the crank pulley and it turned so i said screw it started moving it and it lined up and #1 moved up a hair. all that worry for nothing. thanks though.
