Tips for hooking up Adj. WG
Brocks GN
I just got an Adj. wastegate actuator and was wandering what is the best way to install this thing? Any tips I should know about before I begin? TIA
Just bolt it up to the turbo, lenghten the wastegate rod until it's approx. 1/8"away from the wastegate arm, then pull the wastegate rod out and onto the wastegate arm. You want enough pressure on the wastegate to seal the wastegate puck.
