To much oil pressure?
101prf
Anyone have oil leaks due to high oil pressure? I have the bypass spring in the pump @ 70 psi (yellow spring). With the new engine the oil pressure is at 70 at 2500-3000 rpms. What should I set the bypass at?
Any suggestion for oil pressure relief spring? I have springs for 40psi, 60psi & 70psi. I think I'm going to put in the 60psi - I was told 40 was plenty but i'm not sure. I Rev it close to 6000 rpm. Any advice would be appreciated.
70 is fine. Its not like the car is going to run 70 psi all the time, only under WOT and maybe cold startup. Oil pressure shouldn't have any effect on leaks.
