If I put time and money in my car toward going fast, Im sure it would be a runner. What your car vs. my car has to do with the subject Im not sure, but I havent done anything to this car other than get it running right as a daily driver. You've seen dyno reports in magazines. Ive RUN dynos. Youve done hogging out and gasket matches. Ive done real work with flow benches on real race motors.....since you brought it up....nascar engines, as well as many other race and street motors. I did my first valve job on my 63 nova when I was 12, back in '83. Im mentioned in this months issue of 5.0 for my.....PORTING work. 4 years ago I beat the best in the business in hp with my intake manifold design for cobras. 60rwhp gain at redline with no low rpm loss on naturally aspirated, stock heads/cams motors. Unheard of, and I didnt do it by hogging out anything. I didnt even open up the runners. Plus my daddy can beat up yours.
Like I said, if you have a port misalignment, you will see power gains. But once a runner, from intake to valve is aligned, should now put you at zero...a starting point. If you were behind the starting point because of it not being right, that doesnt mean that a gasket match kicks ass and is almost as good as a real port job. Dont know who you're arguing with on that point. The subject here in this thread, is ****ty port jobs versus good ones. I know you're a proponent of ****ty ones, but thats not how I roll.
Turbulence is not always a bad thing, (Laminar flow isnt be all end all god of flow patterns...sometimes you want it) and I have to argue with the point that an intake runner/head port misalignment causes more turbulence than anything. A poor short side radius/pocket/seat/shroud can cause ALOT more damage to flow where it counts the most. If I relied on magazine editors for all my tech knowledge, I would have a spiralmax in my intake and 4.88 gears with a 6000 stall converter. Most of those guys studied journalism in college...not 4 hours a day in auto shop.
Stop reading articles and using them as your rule of measure.
You want a mild gain and your ports are misaligned? Do a gasket match.
You want to do "extensive porting"? Dont hog out AND do a gasket match...dont see how you can do both like you insisted he should do. If you do "extensive" porting, do it right. How are you arguing with that point?
