To run a " J " Bracket ( Turbo Bracket ) or not ?
Turbo Keith
TURBO KEITH
Sep 16, 2015
1,445
352
83
New Albany , Ms
I am thinking about running a turbo blanket on my turbo but I cant with the J bracket , Is it ok to remove it being its for the turbo shield and I know the turbo bolts to it also . Just wondering how much support it does give the turbo bracket does support the turbo . Thanks for the input Fellows
Dhos1
member
Apr 14, 2012
927
52
28
50
Texas
I’m no expert, but I asked the same ? sometime ago and got mixed reviews. I chose not to run mine. Been about 2 years now, I haven’t had any issues.
  • Like
Reactions: Turbo Keith
RUQWKNF
KEEPER OF SECRETS
Staff member
May 26, 2001
2,426
292
83
47
NEED TO KNOW BASIS
s78.photobucket.com
Here's the deal.
The sole purpose of that bracket, other than something to mount the heat shield to, is too help relieve the weight of the turbo on the header. Without the J bracket, the full weight of the turbo is out there bouncing around when the header starts to get hot, starts to glow cherry red under WOT and pliable. Eventually, this will heat fatigue the headers, especially if stock, you will see cracks start to form around the bulges/folds of the main tube and where the primary tubes are welded to the main tube. I have been screaming it for years, as I've seen a bunch of cars with a cracked passengers side header caused by not running the stock heat shield, "J" bracket. Cars that are not driven often, or only raced and put back in the garage will definitely take a lot longer to crack the header. But a street car that get's abused weekly / monthly will crack a lot sooner. So, IMHO, for longevities sake, you gotta run that bracket.
More food for thought, stock headers can be upwards of 34 years old if they are from an early "86 model. Typically produced in late "85 for the "86 models is not uncommon. And we all know the steel used, was barely passable back when they were new. If you choose not to run a turbo heat shield, at least do something to fab up a similar bracket, or alter the stock one so that the turbo's weight is still supported. No matter which headers you run.... they will absolutely love you for running any type of turbo bracket. It was the very first thing I put back on my current car when I got it and all 4 of mine have had the stock bracket. Pic attached are some of the weak spots on the stock header that I've seen crack before.
Just my O2's worth.
-Patrick-
NY Twin Turbo
All the good stuff.....Times 2.
Dec 10, 2014
2,478
837
113
47
Westchester NY
Here's the deal.
Just my O2's worth.
-Patrick-
Keith, everything Pat has said above is dead on. I learned this a long time ago when I had a stock set-up.
And it is exactly for this reason that when I fabbed up my set-up, I made 2 brackets that independently support and suspend the turbos in place. My headers can be completely removed and the turbos will just hang there . Not a single ounce of additional weight should be added to glowing red-hot steel.
Keep the J.
seedling
611
411
63
52
Baton Rouge, LA
Here's the deal.
Just my O2's worth.
-Patrick-
My thoughts exactly! Patrick might know about this, as I haven’t seen this on another Turbo Regal. However, when I had the BGC extended SLIC on my car it had another bracket that came off the front of my cover and attached to the SLIC. And when I switched to the Kenny Bell fmic I noticed that I could feel very minor difference. Not quite a vibration, but, it doesn’t feel as smooth as it did before I lost the extra brace from the slic to my front cover. Not sure if this was a BGC deal or who made it but it was a simple design that could easily be replicated without any fabrication even. Just a piece of aluminum flat bar is all.
Anyways, maybe Patrick can give you more on that. But, I’m thinking about adding more bracing (not less)! Just my opinion though.
seedling
611
411
63
52
Baton Rouge, LA
I forgot to add that my factory stock “original” headers made it 93,000 miles without ever having even a hairline crack in them (no repairs of any sorts that I’m aware of)! Unfortunately for me, within 300 miles of removing the additional Bowling Green Customs extra brace (from front of t cover down to slic), my headers cracked. Coincidence or not? We’ll never know now, but, sure looks suspicious.
Top Bottom
