When I first start the car after it has sat for a few days, there is a very faint emission of blue smoke that lasts for about 30 seconds. After the car has warmed up and is shut down then restarted, there's a much more pronounced puff of blue smoke that comes out all at once. It's an appreciable amount of smoke. I'm able to let a puff go by, but it's gotten worse and to the point where I feel I need to do something about it.
I can not tell if it smokes under boost and I also get some oil in the driver side breather.
Here is what I've checked or replaced in hopes to alleviate the smoking problem:
Valve seals.
ACDelco PCV.
Cold compression test. One cylinder at 147 and the rest at 155/160.
Intake tract for oil residue. None there.
Turbo shaft. It's tight.
If the seals were bad in the turbo, would the shaft still be tight? I think this is true, but I'm not exactly sure. The turbo is the last thing I can think of to open up.
Valve seals.
ACDelco PCV.
