May 28, 2024 #1 G GNandTTA Member Joined Jun 5, 2001 Messages 563 Looking for the torque amount and procedure for exhaust manifold bolts on Champion GN1 aluminum heads. Did a search on here and general Google search and did not find anything.
May 29, 2024 #2 G GNandTTA Member Joined Jun 5, 2001 Messages 563 Called Champion. 12 - 15 ft lbs if using factory bolts. Check and retighten after engine is warmed up a few times.
May 29, 2024 #3 BEATAV8 The Engine Whisperer Joined Feb 14, 2002 Messages 5,622 Studs are highly recommended over bolts. ARP black oxide with 12pt nuts. For the extra long variants you can use set screws from fastenal.
