ALL STAINLESS
about $50
1/2' eye bolt with 1/2' nut
1/2" turnbuckle and 1/2" nut to use as a jam nut for the turnbuckle.
To hook in the frame I used an old ratchet strap that had a double bent hooks on each end to hook on the bottom turnbuckle hook.You only need one hook from the ratchet strap.The ratchet strap hook hooks into the frame and the bottom turnbuckle hook hooks into the ratchet strap hook eyelet.
I can take some pics of the frame if need be.
about $50
