Tps reading
434nova
I am only getting 82% reading from my tps when the car is off. I am seeing in my xfi when I floor it it only reads the 82%. Is this normal or should it read 100%. Thanks
Do a tps calibration. Super easy. Make sure your iac is good after you do so
View
System config
Sensor calibration
Tps
Click auto cal
Press ok
Close screen
Press pedal to floor and release
Reopen tps calibration
Un click box
Close
Verify tps reading
Check to make sure that when the pedal is on the floor that the TB is fully open. Floor mat, stretched throttle cable, bent mounting bracket and so on can prevent a fully open TB.
RemoveBeforeFlight
RemoveBeforeFlight
Turned out to be the floor mat, it was wedged under the pedal.
