Trans cable bracket clip?
GeneralB44
www.pinkhumpy.com
Hi, can someone show me a picture of how the connection looks under the car where the trans cable connects to the bracket?
I had mine slip out and I had to pop it back in to get the car in gear but I don't know if I'm missing a clip or something. Thanks!
Pull the cable back and put the large round ring to the right of the bracket . There is a step that fits in the bracket , push it flush to the bracket and slide the clip on the other side of the bracket . I would show you mine but it broke today and I just ordered a new cable from Kirbans . Sam
Thanks! Good luck with your new cable!
I followed your instructions but I'm not sure if I got it right. Maybe the clip on mine was side ways? I'm attaching a pic of what it looks like now. Is that right now?
Also is the cable supposed to bend so much as in the other picture ? I can't tell if it's broken inside?
Thanks again!
That first picture with it in the bracket is correct . The bend is just where the braided cable starts , it is not an issue once the cable is mounted correctly .
