Trans coller line Metal clip bolted to oil pan
PaulRV6
This clip, which way does it go: large loop is on driver or pass side? Right now it is facing out (pass) but it rubs on crossmember and it seems like if it was switched it would have more clearance. Also what goes thru the hoop? Thanks
paul
Cooler line clip
On my car I'll assume its correct, the large loop faces the pass side to work as a tension spring against the frame. One cooler line is between the oil pan and the clip. The other line is clipped in the middle. Nothing goes thru the large loop.
Thanks Scott, that is the way mine is now but I have had the engine in/out and apart a few times. I guess I'll assume it is correct.
paul
