Translator + question
BJM
Senior Member
If I change a timing setting in the T+ do I have to turn the car off and on again to get the readings to "take". If they work on the fly then I would probably mount mine in the car somewhere. Otherwise I will probably leave it under the hood.
As far as I know you can change it on the fly,mount it in the car keeps it safe from rain and more fun to play with.
I know at least the base MAF settings are only read at power up so I was wondering about the timing adjustments.
The DIP switches are read at power up.
The dials are read continuously. Any change inthe dial setting takes effect after about .5 sec.
TurboBob
