transmission id #'s
III'S 87 GN
i just checked my transmission id tag,it is coded brf but the serial number dont match my vin # !!!
should it match my vin # ?
where do i find engine id number ?
thanks
Yes the number part should match up to the end of the vin #.
The motor number is just above the top bolt for the little shield that guards the flex plate and tranny converter, drivers side.
Need a mirror some brakeclean and a rag and a good light to find it.
Very small font either 8 or 10 stamped into the boss on the engine.
Vertically stamped vertical boss.
ok,
thanks
however i cant figure out the tranny thing.
i have 4 #'s then brf then 4 #'s,they dont match vin.
could this be a replacement trans ?
or just something goofy with the tag ?
thanks
Tranny VIN ID is not on the BRF tag.
I assume your BRF tag is on near the tailpiece passenger side?
If so you must look on the drivers side. There is a boss just above the tranny pan to gasket mating surface, about 2/3 back from the front of the tranny. The boss will have a stamped number on it about 10 font horizontally placed with most of the VIN #'s on it.
That one you can't miss finding, I hope. ;)
