If you are maxing out the MAF at wot, then the T+ won't help much without the Extender. It adjusts fuel by modifying the MAF values, so it can't add any fuel once it reaches 255.
You could use fpr to adjust wot and then the T+ for base fuel and get blms back in line if your chip is too far out of wack. Otherwise you might as well adjust fpr to tweak wot and let the chip (blms) take care of the rest. I could be wrong, but I think that the chip makers spec a fpr setting as a starting point and slight tweaking is perfectly acceptable.
Not that there isn't something to be said for using the T/T+ for the modern maf benefits alone.
HTH,
Tom
