Trunk Release Question
RSTTYPE85
RSTTYPE87 NOW
Well, I can't get it to work. Any fuses for this besides in the fuse box? Any help would be greatly appreaciated.
Thank,
RS:confused:
I don't think so. Just one line going from the release mechanism in the trunk to the button and another line going from the button to some 12v ignition supply (so the key has to be on for the trunk release to work).
Then again, mine wasn't an RPO. I installed mine myself and this is how I wired it.
Wire can break inside the coating down by the drivers hinge area in the trunk.
I think there may be a connector down there so you can test to see if you have power when you press the button.
Make sure the ground is good to the trunk area as well, case grounded unit I believe.
